93 lt1 problem
Old Aug 21, 2009 | 05:27 PM
sleeper93z's Avatar
Default 93 lt1 problem
The car will crank when it's cold then will run fine until it warms up then just dies. Iv'e changed the fuel filter, checked the schrader vavle, replaced the coil, fuel pump seems to be working but i was told when it was tuned that the pump was weak. would the pump pump good enough for a short time to run the car an then give out. Any suggestions or tips would be great. thanks
Old Aug 21, 2009 | 06:04 PM
1badzee's Avatar
Do you have a cat still?
Old Aug 21, 2009 | 07:02 PM
ss.slp.ls1's Avatar
Only way to test the pump is to hook up a fuel pressue gauge and monitor the fuel pressure.
A bad ICM or bad o2's would be my guess.
Old Aug 21, 2009 | 08:59 PM
1993 z28 f1's Avatar
HEY:
How many miles, where you located, and what have you done to the car last?
Dub
When In Doubt Do Without
Old May 26, 2011 | 01:38 PM
TimsLT1's Avatar
Any more on this? I have a 95 Z28 A4 same symptoms. Driving me insane.
Old May 26, 2011 | 01:46 PM
djjab57's Avatar
I understand your looking for answers but look at the dates, this is from 09
