o2 Sensor Question 93 T/A
I believe the 93 only has two O2's, 1 located on each exhaust bank. The third one (after the cat) is only to measure the catalytic converters efficiency and 93 doesn't have it.
Mine were tested with a diagnostic tool (not a scan tool) that lets you watch the numbers they control jump around. If they are quick to respond and make large jumps up and down (in numbers) they are working well, if they are slow/lazy to adjust numbers and jump in small increments they're not working well. Hopefully someone will confirm this for you!
