Nitrous with stock bottom end? How much
Old Aug 25, 2009 | 10:46 AM
Jazz-LT1's Avatar
Default Nitrous with stock bottom end? How much
I'm finishing up a rebuild with a near stock bottom end.
Using a 1996 LT1 with PM rods and ARP bolts, stock crank, and Wiesco forged pistons.
The motor also has a CC305 cam, ported heads, bigger Raceflo valves (2.00/1.56), 52mm TB, 30# injectors, 1.6 Pro Magnum Rockers
I'm expecting 375rwhp. Can I still spray this without destroying the motor? I was thinking about a 75 or 100 shot.
Old Aug 25, 2009 | 10:55 AM
RED94Z28's Avatar
You'll be fine with a 150 shot with arp bolts and forged pistons..
Old Aug 25, 2009 | 10:58 AM
T/ALT1's Avatar
yeah I sprayed 150 on a 365rwhp N/A stock bottomend Lt1 and it ran 10.80's@125mph but didn't last too long. So I built a similar setup to yours and it worked great. later
Old Aug 25, 2009 | 11:01 AM
Jazz-LT1's Avatar
Sweet. I was hoping to see a mid 11sec time with a 100 shot. I don't expect the car to get into the 10's because its actually set up for autocross and won't hook up with that supsension setup. The nitrous is just for a little added punch. You never know when another 100hp might come in handy.
Old Aug 25, 2009 | 12:06 PM
gregrob's Avatar
Are you having the assembly balanced?
I wouldnt be afraid of a 100 shot at all. Forged pistons and I'd hit it w 200+
Old Aug 25, 2009 | 12:43 PM
Jazz-LT1's Avatar
Yes, the rotating assembly was balanced. I assembled it myself. Clearances on the mains were about .0025, pistons are forged, but I'm staying with 100 shot since the car will already overpower the chasis on a drag strip and is overpowered for autocross as well. The only place that I'll ever get to use the nitrous (once installed) is for purging to scare guys in Z06's -- I'm also making room in my garage for a 2005 Z51 Corvette once this build is done.
Old Aug 25, 2009 | 12:56 PM
kinglt-1's Avatar
Your only installing nitrous to purge at z06's?
Old Aug 25, 2009 | 01:06 PM
airfix's Avatar
If thats all you'll be using the kit for is to purge, you might aswell just get the purge show kit, I think zx makes it. It's just purges, to make it look like ur spraying
