Water Pump Help Needed
Old Aug 26, 2009 | 10:25 PM
Nads06111's Avatar
Default Water Pump Help Needed
Couple issues. First, I cannot get the coupler off the water pump gear. Has anyone had these issues?
Also I installed the water pump drive seal into the timing cover before I put it on the car. Should I take it out and get a new one? Or will the seal still work?
Old Aug 26, 2009 | 10:28 PM
italiangto's Avatar
It takes some pb blaster on that coupler and some leverage mine was tough too.... Make sure you use felpro gaskets and let it seal for a day to ensure no leakage due to you opti. I don't know your other part.
Old Aug 27, 2009 | 06:38 AM
Badazz 97 TA's Avatar
no you wont have to get a new one. the seal will still work provided it doesnt rip when you install the cover back on the motor.
Old Aug 27, 2009 | 03:09 PM
Nads06111's Avatar
where can i get the o-rings that go under the coupler?
a part number would help
