pickin up the new setup
Old Aug 27, 2009 | 11:14 AM
1mean96ss's Avatar
Default pickin up the new setup
Just had to post my excitement, i recently spun 4 rod bearings after a cam install. Somewhere along the lines it lost oil pressure once it got above 180 degrees. Well a friend of mine was selling his motor and cut my a good deal i couldnt pass up. Block has 65,000 miles and is heads/cam/ported intake. So needless to say im pumped. I just have to build my th350 and im ready to go.
Old Aug 27, 2009 | 12:51 PM
gregrob's Avatar
Sweet what porting on the heads and what cam?
Old Aug 27, 2009 | 01:56 PM
kinglt-1's Avatar
x2 more info please!
Old Aug 27, 2009 | 02:01 PM
SoxXpupPeT's Avatar
sounds pretty damn good so far! x3 on more specs! fully built bottom ?
Old Aug 27, 2009 | 02:41 PM
ss.slp.ls1's Avatar
x4 for more info...H/C/I can mean anything...
Old Aug 27, 2009 | 07:42 PM
1mean96ss's Avatar
Its fully ported heads (slightly better than LE3), ferra valves, ported intake to match. Bret Bauer custom cam 232/232 .608/.608 on a 108 LSA. Stock bottom end with about 65,000 miles. I already have full bolt-ons with 3.90 gears, soon to be a th350/4000 stall. Weight reduction
Old Aug 27, 2009 | 07:46 PM
ss.slp.ls1's Avatar
Nice, post a video when you get it running.
Old Aug 27, 2009 | 07:49 PM
1mean96ss's Avatar
Only thing is i have to do something about the wiring harness cause its a 94 or 95 block.
Old Aug 27, 2009 | 07:58 PM
ss.slp.ls1's Avatar
Blocks are identical. Only issue you'll have is that a '94-'95 block won't have a provision for the CPS. You can do one of two things. You could swap the '96 reluctor wheel, timing cover, and crank hub & balancer over to the new engine. Or you could just leave the CPS connector ziptied somewhere and tune out the code. I would swap over the '96 stuff. I like having misfire detection...
Another issue you could encounter is that the new engine has the oil pressure sensor on the side of the block rather than the back of the intake manifold. (If it's an early '94 block) In that case you can either extend the oil pressure sending unit wires to plug into the new location or you can relocate the sensor to the back of the intake and plug up the current location hole.
Old Aug 27, 2009 | 08:07 PM
1mean96ss's Avatar
Its a 94' i just found out, and the oil pressure sensor is at the back of the intake like my 96. It has an MSD opti on it with the wiring coming off the opti but i cant put it into anything in my harness.
Old Aug 27, 2009 | 08:32 PM
1mean96ss's Avatar
It looks just like this........... http://www.summitracing.com/parts/MS...1/?image=large
Old Aug 28, 2009 | 01:31 AM
ss.slp.ls1's Avatar
Yes you should be able to hook up that opti to your current harness. The LT1 opti metripack is the same for all years. You just have to disconnect it at the middle of the passenger side of the intake manifold:
http://shbox.com/1/evap_sol.jpg
Old Aug 28, 2009 | 01:50 PM
1mean96ss's Avatar
Sweet thanks for all the help
Old Aug 28, 2009 | 09:58 PM
Verz's Avatar
That sounds eerily familiar to a guy here in town thats been helping me out.
Old Aug 29, 2009 | 09:33 AM
1mean96ss's Avatar
Mine came from a friend out in wentzville, had a black Z on bigs and skinnies. Named Brandon Harke
