problem found! pics inside
my driver side 5 + 7 plugs have aluminum caps that go over the plug wires for exactly this reason..does anyone know where i can order something similiar to protect all my plug wires?
yah that rail is only on the driver side, and even if it were on the passenger side, it only protects the wires, not the boots.
http://www.summitracing.com/parts/ACC-170081/
I would suggest going with a Taylor 8mm wire or similar...
If so THAT is why you have a miss. Solid Core wires are NOT for computer controlled cars, as they cause MASSIVE EMI/RFI interference, thus causing a ton of issues, of which the missing is the most apparent.
There is no reason to run a solid core wire on a LT1, REGARDLESS, as the cap/rotor is not built to handle the kind of excessive voltage/current that solid core wires can produce. Hell, the amount of spark scatter you get with a CDI iginition box and a high-output coil inside the optispark is unreal with regular resistor core wires.
I personally have dealt with a few cars where people tried solid core wires as a performance upgrade and it is now one of the first things I check for when there is missing/ignition issues.
