CAI HP limitations?
Old Aug 28, 2009 | 03:58 PM
Stroked96Bowtie's Avatar
Default CAI HP limitations?
For a LT1 style replacement CAI (SLP, K&N, Moroso, etc) is there a HP limitation with these setups? At what point would one consider something more custom?
Im all set to have a custom piece made next week, but wondering if its really worth it?
Old Aug 28, 2009 | 04:13 PM
trippinholyman's Avatar
cfm = rpm x displacement / 3456
how big how high you gonna spin it?
even if you spin it to 7000 and have a 6.0...
7000 x 366 / 3456
741 cfm
that's ridiculous. the CAI filters usually flow 900-1000 cfm IIRC, check their sites for actual cfm ratings
on second thought also remember that if you don't change it every run its gonna get some dirt on it and clog it a little bit. so keep that in mind too. don't necessarily go for the highest flowing one..find the one that flows the most after being used a bit i suppose? unless you are gonna clean it or replace it all the time..can be costly haha
Old Aug 28, 2009 | 04:48 PM
7000 x 366 / 3456
741 cfm
Good formula to have, I was looking on the K&N site and didnt see any cfm ratings. Seems they would have a cfm rating for the entire CAI setup, not just the filter. So is the filter the bottle neck on a CAI? Its not limited once it gets passed the filter? If the filter is the primary restrictor on a CAI, that would explain why they dont have the entire system rated. Im hoping Im making at least some sense here...haha.
Old Aug 28, 2009 | 05:13 PM
ss.slp.ls1's Avatar
Unless you have a radical set up, and I mean radical, concentrate your efforts elsewhere...
Old Aug 28, 2009 | 05:19 PM
No not really. I know the projects are lining up...transmission has to come out soon...ugh.
Old Aug 28, 2009 | 06:12 PM
FASTFATBOY's Avatar
K&N told me theirs would flow 1300 cfm with a larger filter. That supports a LOT of ponies.
Old Aug 28, 2009 | 06:28 PM
Bersaglieri's Avatar
I wonder if anyone ever dug up CFM flows on the different CAI's, LPE, SLP, K&N, Moroso, etc....
Then I wonder, the LS1 airbox cant flow much more...so the gains must be from fewer turns...
-Dustin-
Old Aug 28, 2009 | 06:56 PM
Puck's Avatar
-Dustin-
The K&N FIPK flows more then a 58mm monoblade...it won't be a restriction unless the filter is very dirty.
I said a few times that I dyno'd back to back with a H/C 350 spinning to 6400 and only made less then 2rwhp more with an open TB then a FIPK.
Unless you are a high rpm 400+ Ci NA engine or turbo/supercharged a CAI is more then enough IMO.
I will be doing back to back tests with a FIPK and an LS1 lid on a big headed 7k rpm 383 once my build is together, both dyno and strip. I expect very similar numbers on both.
Old Aug 28, 2009 | 07:26 PM
Definately post up the numbers and settle the lid dispute.
-Dustin-
Old Aug 28, 2009 | 10:01 PM
FASTFATBOY's Avatar
I can tell you this, there is almost zero restriction from my LT1 WS6 airbox setup. I did a key on engine off MAP reading of 103.5, WOT map was 102.1, stayed above 100 kpa the whole run.
Old Aug 28, 2009 | 10:46 PM
Puck's Avatar
-Dustin-
I doubt it would settle anything, its been covered a million times but everyone has their own views.
Personally I think its useless with anything less then an AGGRESSIVE NA 396 or a FI setup, but other people swear its good for 20hp on a 355. I don't see how considering I didn't even get a 5hp flywheel difference with NO intake, and the intake would need a considerable amount of positive pressure to gain that much, but to each his own .
Old Aug 28, 2009 | 11:48 PM
hitmanws6's Avatar
the CAI will work just fine. and i have the PN for the bigger filter on the K&N FIPK if you are interested
Old Aug 31, 2009 | 11:53 AM
Thanks for the inputs guys.
Think Im sold on trying to stick with an aftermarket LT1 CAI.
Now my setup isnt exactly stock, Ive got an Aarons elbow (w/AS&M TB) on a single plane (victor-e). Id be interested to see if anyone knows if there will be fitting issues, I know someone has tried this.
Old Feb 15, 2014 | 11:53 AM
ahritchie's Avatar
Bringing this back from the dead.....what were the results? Don't tell me it's 5 years later and no progress
Old Feb 15, 2014 | 12:03 PM
Puck's Avatar
No, of course not 5 years...just 4 and a half LOL. Motor itself has been finished for over a year but I haven't messed with it in a while. I swear in my head I stopped counting at 3 years lmao. Now the build is always "about 3 years old".
I paid off a motorcycle, bought a new one, and then got a second LT1 so the Z28 has been on the back burner for a while now. I am focused on rebuilding the TA as a decent baby cam/ported stocker DD, and then will be back on the Z.
No ETA, sorry :p. As a bonus though I am going a lot more aggressive on the rest of car since it will barely be seeing any street duty with the bike and TA replacing it.
Old Feb 15, 2014 | 12:13 PM
DUDCOUPE's Avatar
I made my own cai, 3.5 pipe all the way to the elbow. Ceramic painted so it doesnt get to heat soaked. Goes all the way down below the bumper for fresh air
Old Feb 15, 2014 | 12:19 PM
cardo0's Avatar
Again i like the Moroso Honker.
http://www.moroso.com/articles/artic...&catcode=34001
cardo
