383 build questions
Old Aug 29, 2009 | 01:03 PM
redlineracing's Avatar
Default 383 build questions
Hey guys.
I have a 1994 Z28 that is too damn slow. My current mods are pacesetter mid-lengths and a K&N FIPK. My budget for this project is $3,500.
The car runs fine right now, but the oil pressure is getting somewhat low. That being said, I would like to rebuild the engine. I will do all of the work myself, so please factor that into the cost.
I am also going to rebuild the 4l60e and purchase a stall.
Now I would like some ideas from you guys.
Remember the budget is small.
so..... WHAT SHOULD I BUILD?!
Will i have enough money for a 383 build? Or should I just rebuild the 350 to stock specs and maybe spray it??
All input is welcome!!
Old Aug 29, 2009 | 01:19 PM
RamAir95TA's Avatar
You want to rebuild the motor, rebuild the trans, and pick up a new stall for $3500? Unfortunately that's not going to happen.
For $3500, you can probably get a base stock-ish rebuild on the motor with a cam swap, and that's about it.
Old Aug 29, 2009 | 02:33 PM
fleetmgr's Avatar
The only way you'll accomplish this with a $3500 budget is if you rob a speed shop for the parts.
Old Aug 29, 2009 | 02:42 PM
myltwon's Avatar
if you were just saying engine I'd say you'd be able to do it, but trans is atleast another $1500+ for the build and then cost of convertor. basically you'll have <$1500 for a motor rebuild
Old Aug 29, 2009 | 03:36 PM
ThreeHonks's Avatar
$3500 is not even a good budget to just rebuild the motor. Do it once and do it right
Old Aug 29, 2009 | 04:42 PM
1badzee's Avatar
spend the 3500 on a heads/cam setup
just saw that your motor has low oil pressure.. oops lol.
PM me if you're interested in buying a ready to go motor.
Old Aug 29, 2009 | 05:35 PM
how do you figure $1500 for a transmission? I am rebuilding it myself. A master overhaul kit doesn't cost near that.
Old Aug 29, 2009 | 05:47 PM
A20SVT00's Avatar
go to the classified there are good deals right now from engine to stall converters to cams
Old Aug 29, 2009 | 05:49 PM
RamAir95TA's Avatar
If you've got the knowledge, tools, experience, and skills to rebuild a complex 4L60E, more power to you.
Most people leave rebuilding A4s to the professionals. I went through Performabuilt to build my 4L60E. Cost me $2200 with a custom converter.
Old Aug 29, 2009 | 06:16 PM
tonskiguy's Avatar
Take the block to the machine shop for new bearings and zero deck. If the cylinders are OK, just have them honed and install new file fit rings. Reuse the stock oil pump if it looks OK, but upgrade to the 4130 shaft and steel collar, also use the white spring in the pump. You should be able to accomplish that for $1K. Send your heads to LE or AI and have them ported and have them spec a cam for you. Use a felpro 1074 head gasket to keep the quench to about .039". Watch for a good deal on a 52 or 58 T/B and get a tune. You should be able to do that for $3500. Might even have enough left over for some gears. Good luck!
Old Aug 29, 2009 | 06:52 PM
RamAir95TA's Avatar
Doing a rebuild without boring the cylinders and line-honing just to save a buck is a bad idea.
Old Aug 29, 2009 | 08:44 PM
tonskiguy's Avatar
OK, I guess I take it for granted that align boring goes with the fitment of new bearings, my bad for not specifying that. I do think the cylinders can be honed without boring as long as they don't have a taper or out of round confition. The guy is looking for a $3500 performace upgrade and I think I gave him a solid plan rather than no hope and critisizm.
Old Aug 29, 2009 | 11:19 PM
LT1/TA's Avatar
I think you can put together a good motor and trans with $3500 by doing it yourself.I would do a few upgrades to the trans and use some good steels,clutches,and band.Try to find a good stall in the classified,I don't see the trans taking to much of your budget and they are pretty simple to rebuild. Unless the cylinder walls looked bad I would not bore it,but if you are going to buy new pistons I would bore it.Tonskiguy has a good plan for your engine.You might can even get you some gears also.
Old Aug 30, 2009 | 09:24 AM
lovemyzroc's Avatar
Default Shop build
i rebuilt my 350 and bored it and stroked it to a 383 stroker! Comp Cam XFI cam and high compression pistons, racing rings, whole valve kit and everything and at the end of it all i spent over $8,000 just engine alone. I did have a shop build the engine!
Old Aug 30, 2009 | 09:49 AM
RamAir95TA's Avatar
You gave him a solid plan lacking reliability. Getting new rings to seat against non-concentric cylinder bores is just asking for trouble. Truth is most cylinder walls "look" fine, but it's what you can't see that's the problem. You will not catch me throwing new rings onto old pistons into old bores, ever.
$3500 will get you a basic reliable rebuild with a cam swap on stock heads. Fact is the overwhelming majority (probably 4 out of 5) of folks doing rebuilds, swaps, etc., go over their budget. Been there, done that.
JMHO.
Old Aug 30, 2009 | 11:19 AM
toy96ta's Avatar
I spent over $5K doing my Heads/Cam right. Not sure how you could do an entire motor for $3500 without using inferior parts, or skipping key upgrades. (Of course I also upgraded my clutch, flywheel, fuel pump, TB, EWP, tune, etc.)
Old Aug 30, 2009 | 11:35 AM
myltwon's Avatar
very few people work on their own transmissions so I assumed your idea of "rebuilding it" was sending it to a shop
my 383 build cost around $2k if I remember correctly
Old Aug 30, 2009 | 03:10 PM
1badzee's Avatar
Where the hell is Formato these days! I need a dyno tune! lol
Old Aug 31, 2009 | 08:53 AM
WS Sick's Avatar
Why would you bore and line hone if it is in spec?
A good hone with torque plates will take out any irregularities. if you can lay a straight edge across the saddle of the mains and its in spec why would you line hone a block.
Old Aug 31, 2009 | 11:47 AM
myltwon's Avatar
lol over here in Tampa, contact him he's all over the place depending the time of month
