Question
Old Sep 1, 2009 | 08:49 PM
Z28reggie's Avatar
Default Question
Hey guys i notice tday that my volt meter is sitting low when i am at lights. I was sitting in Mcdonlds drivethru and had the music on which can drop the meter at times when loud but it wasnt loud and in fact i cut it off. Then i hit the gas a lil to move up and it went up so i as like ok maybe i had music up to loud well i stop and look and it drops again and with no radio so i know thats not the problem I put it in neutral and without giving it gas it went up i put it back in drive it drops again Whats up anyone got ideas cuz i sure dont
Thanks in advance and sorry for long post
Old Sep 1, 2009 | 09:02 PM
RamAir95TA's Avatar
I'd assume the alternator to be the primary culprit. Most parts stores will be able to check it for you.
Old Sep 1, 2009 | 09:09 PM
Z28reggie's Avatar
i had it checked once they said it was fine that was about a month ago I looked for sparks like the plug or wire grounding out but didnt seee that either
Old Sep 1, 2009 | 09:11 PM
RamAir95TA's Avatar
You may want to have it checked again. Also, check for broken/loose battery cables and wires.
Old Sep 1, 2009 | 09:18 PM
Z28reggie's Avatar
will do thaks
