where does the braided ground wire go?
Old Sep 4, 2009 | 06:56 PM
AChotrod's Avatar
Default where does the braided ground wire go?
I forgot where that braided copper color ground wire go, that comes off the harness near the coil? Is that one to the frame rail????
Its the last connection I need!!!
Thanks
mike
Old Sep 4, 2009 | 07:17 PM
My95Z's Avatar
On the frame rail above the sway bar(ish).
The other 3 ground endings go to the coil bolts to the head.
Old Sep 4, 2009 | 08:43 PM
FLORIO1STFORM's Avatar
Default ground wire
It goes on the drivers side frame rail just behind the headlight.
Old Sep 5, 2009 | 01:16 AM
riceburnerZ28's Avatar
Yes sir that's correct!
Old Sep 5, 2009 | 10:26 AM
AChotrod's Avatar
Thanks!! I remembered right after I posted this. Still had the bolt in the frame with that other ground on it.
