new engine wouldnt start....
Old Sep 6, 2009 | 11:27 AM
I_Need_Land's Avatar
Default new engine wouldnt start....
got EVERYTHING back together last night.. new engine etc etc....
car wouldnt spin over.... no battery gauge either?
gave up went to bed...
thought about it... i didnt plug in the 4-5 plugs laying on my passenger floorboard that go into the dash...
if i plug those in will my car start? im assuming on them allows a start signal to be sent to the engine, and also communicates with the gauges as far as battery voltage...
Old Sep 6, 2009 | 11:39 AM
94LTZ's Avatar
Yeah you should probably see what plugs are laying there, why were they unplugged?
Old Sep 6, 2009 | 11:47 AM
TRUCKIN's Avatar
I think that would be a good start. I do that stuff all the time.
Old Sep 6, 2009 | 01:07 PM
AChotrod's Avatar
mine fired lastnight on the first try. Plug those back in and see what happens.
Old Sep 6, 2009 | 01:15 PM
it cranks now.. we got no spark...
Old Sep 6, 2009 | 01:22 PM
94LTZ's Avatar
check the opti harness for corrosion and just make sure it's plugged all the way in on both sides, and then look at the blaster coil and ignition module..
Old Sep 6, 2009 | 04:53 PM
the ign module seems to be working fine, its wired correclty as far as i can tell..
what pins on the coil/ icm get power and which ones provide a ground?
