need pcm help
http://shbox.com/1/smfi_devices_injectors.jpg
On a 1994 power goes through C100 A and K to the fuses.
http://shbox.com/1/harness_connector_faces.htm
If they are, then check the Pink on the 2, 4, 6, 8 Injectors and see if they are hot. If not then there is a break in the Harness somewhere.
If they are hot then you have a pretty wierd problem..
