What springs should I run?
Valvesprings are not something to cheap out on. You will be kicking yourself in the *** later if you ended up dropping a valve later. I have patriot dual golds in my ls1 and have hit 7400rpms with a cam over .600 lift with no problems. Definatly a good spring.
