X, H, Y pipes...Headers....Help!!!
1. What is the performance difference between a 1 3/4 primary and a stepped header with a 1 3/4 to 1 7/8? With my mods (in sig) what would you suggest?
2. Should I just get a ory pipe?
3. What are the performance differences between a Y, X, and H pipe? Are the summit universal X, H kits any good?
4. Is having it dumped before the axle going to be too loud for DD use?
5. What will get ride of the annoying drone between 1800-2400 rpm?
If I get rid of the gmmg I was looking at getting the powersticks. Help inform me please! Post up all the videos and sound clips you can! There are so many choices I can't decide. The only thing I do know is that I am getting stainless steel headers. Thanks in advance guys!
2.) If you can pass inspection without a cat then yes an ORY is perfect.
3.) The Summit X-Pipe kits are awesome. Have one on my car. X-Pipes makes a little more power uptop over H-Pipe and H-Pipes make a little more torque down low atleast what the general consensus seems to be. X sounds more racey and H more deep. A single 3" Y into a 3" catback is not hindering you at all at your power level. Once you start doing heads/bigger cam then TD's may offer a few more hp.
4.) YES.
5.) Depends on muffler choice and/or use of cats.
I would not get rid of GMMG for anything. Once you put LT's on it you will see what I mean. Put on the LT's and the ORY and see what you think. You can always add cats or resonators if you want to quiet it down etc.
I'm running LTs with a catted x pipe and bullet mufflers dumped before the axle and its pretty quiet, and no drone inside the car at cruising speeds.
