low idle at random times
So I wasn't trying to hijack your thread but I am going to look into checking my ICM and IAC valve. In my particular situation, if I fiddle with the coil wire as in remove it and put it back on, its right after that when the car decides to fire up again. You aren't alone. Also going to check my O2s, seems to be another pathway to diagnosis for this low idle issue.
Hope that helps.
