Intake Manifold Bolt
Old Sep 10, 2009 | 01:42 AM
Z28Camaro30Ann's Avatar
Default Intake Manifold Bolt
Today I drove my car to Ft. Collins (45 mile drive). Most of you know the issue with acceleration I have been having, but it has ONLY been acceleration...till tonight.
I got to Foco and went to hit the brakes to slow down for an exit......VERY little brakes. acted like it didnt wanna stop. Stopped it finally and it idled rough for a second then cleaned up. Started driving again and the brakes were back, all seemed ok. Stepped on it a bit and went to stop and it was hard again. Had to pump em a little.
Got to Advance Auto because I needed some oil (bad oil leak, getting fixed when I solve this accel issues so I do it all in one sweep) and I saw smoke coming out of a bolt hole on my intake manifold! I knew it was missing, but it was the spot where the additional alternator bracket sits and I was told it did not go through and would not cause a vacuum leak...well APPARENTLY it does!
Now my next issue. I cant find a damn bolt to fit this thing...anyone have an extra I can snag???
Old Sep 10, 2009 | 01:49 AM
gregrob's Avatar
Good God man
I have one we can use to size it up. I do happen to sell fasteners for a living.
I can help you figure out the dia, length, and thread pitch. Its not that hard..
Call me
Old Sep 10, 2009 | 01:53 AM
Good ****. I DID manage to test the top end slightly on the way back though...just to see how she rides. Got her to 130mph in 5th at 4400 rpms. Slowed it down from there. It got there fast, ran smooth, and didnt seem to have an issue...
Old Sep 10, 2009 | 01:58 AM
airfix's Avatar
Damn man, why would you leave an intake bolt out for so long? its been weeks since you finished that god awful swap.
Old Sep 10, 2009 | 02:03 AM
Like I said, I was told by someone I trusted (apparently I shouldnt) that it was only for the alternator bracket and did not go through...I was told I could remove it and have no leak. This is the first time I noticed anything like this from that bolt. The bolt that WAS in it when I had that bracket on there, only sat loose ever since the day I got the car. I noticed that the first time I took the alternator off. The bolt they used was too small to thread so they just said eff it and left it that way and let the weight/pressure of the alternator hold it in place. I removed that bracket when I did this swap, but did not have a bolt to fill that spot. Had I known it actually DID leak, I would have told that guy he is a moron, and gotten a bolt in there immediately.
Now that I know about it, it WILL be fixed ASAP. The car will NOT be driven till it is.
Old Sep 10, 2009 | 02:06 AM
And I know I know, I prolly should have paid more attention and double checked that, but I forgot...my bad
Old Sep 10, 2009 | 02:07 AM
1badzee's Avatar
Shame on you..
Old Sep 10, 2009 | 02:10 AM
tsk tsk tsk...at least THIS mistake didnt bend all my valves and cost me 550 bucks lol
Old Sep 10, 2009 | 02:11 AM
If this fixes my acceleration issue, I can FINALLY fix my distributor and oil leak lol
gregrob's Avatar
Joe / RamAir95TA told you it NEEDED fixed on here... I'm just too lazy to look up the post.
Old Sep 10, 2009 | 02:14 AM
if he said it, I must have missed it....I have so many posts going on I prolly accidentally skipped over it. But its all good, it will get fixed now
Old Sep 10, 2009 | 02:28 PM
RamAir95TA's Avatar
Originally Posted by RamAir95TA
You NEED to replace the missing intake manifold bolt.
Get it scanned, then come back with the results.
Have you checked your fuel pressure at all?
I told you that almost a month ago. Get it together will ya?
Old Sep 10, 2009 | 03:35 PM
Badazz 97 TA's Avatar
vrooom vrooom stall bog
Old Sep 10, 2009 | 05:14 PM
Spartan7's Avatar
Intake bolts are 3/8x16-1.38. GM # 9439918.
