Taking off intake
In answer to a previous question, it was not obvious when I took mine off that it was leaking. However, you have to remember that the oil pressure can be 40+ psi, so it could have been a very small leak and still given the results you observed.
why????
i think it is because i used a channel lock pliers instead of using the right socket on the OSU, so i got to replace that again, without taking the intake off
absolutly!!! You need to remove the lifters if not they will fall in the motor upon removing the cam, not to mention you also need to remove the oil pump drive unit at the rear of the block or the cam wont even come out.
