cam change = spring question
Old Sep 12, 2009 | 08:22 PM
Steel185's Avatar
Default cam change = spring question
stil working on building the motor for my 95 Z28. I had the heads cleaned up with a valve job at the machine shop, they put on springs and set them up for the cam I was planning on using, a CC503 (224 int./230 exh. 0.503/0.510 lift 112LSA). I've decided to go with a LE 218/224 .544/.544 111 LSA. Now i don't know what type of spring is on the head and I figure I need to change them to work with the new cam. Does anyone recognise this spring?
[IMG][/IMG]
The machine shop reciept says ZZ-4 spring and retainer, put it doesn't look like pictures I've found. I found info on K-motion green stripes but couldn't find a picture of their green ones, but their pink stripes are a different stripe. Does anyone know?
Old Sep 13, 2009 | 10:54 AM
My95Z's Avatar
Why not just call the machine shop and see what they put on?
Different spring companies use different colors for different things, you can't go by the color stripe.
Old Sep 13, 2009 | 05:36 PM
BALLSS's Avatar
what ever brand they are...ask machine shop for their "specs" open and close pressure.
then ask LE if that spring spec will work with their cam
Old Sep 14, 2009 | 07:36 AM
NightTrain66's Avatar
LS1TECH Sponsor
they could be some cheep $16 to 40 "Z28 springs" that alot of machine shops use on hyd flat tappet stuff or even MILD (stock like) hyd rtoller cams.
The material that the spring is made of might not be able to handle a semi aggressive lobe that opens/closes the valves faster than the above mentioned cams.
You want to make sure that the springs have AT LEAST 130 lbs on the seat and 320 lbs open pressure to work with those lobes. Make sure they have a set up ht that doesn't coil bind until AT LEAST .580 lift (giving you .036 clearance from the .544 lift of that cam).
Ask them for seat pressure, open pressure and coil bind at that installed ht. Do not tell them what you need until AFTER they tell you what the springs have or amazingly these springs will have what you need, lol.
If they can not answer you of if the #'s do not dit what I have suggested, swap springs with a better set.
Lloyd
