Porting intake?? Worth it??
Old Sep 12, 2009 | 10:21 PM
94LTZ's Avatar
Default Porting intake?? Worth it??
Ok so i'm looking at porting a stock intake on th runner side and try to get better flow from it.. Is it worth it or should just leave it be.. I've heard of people porting them to much and causing turbulanc from the intake being porter larger then the heads on the intake side..
Old Sep 12, 2009 | 10:36 PM
Wicked94Z's Avatar
plenty of guys making over 400 rear wheel on an unported intake, stock heads there's better things to spend money on
Old Sep 12, 2009 | 11:01 PM
94LTZ's Avatar
Yeah i think right now i need to focus on suspension rather then power... God i never thought i would say that lol..
Old Sep 13, 2009 | 12:04 PM
pyro719's Avatar
I cut 1.72 60ft on 100% stock suspension. I need more power
Old Sep 13, 2009 | 12:11 PM
94LTZ's Avatar
Lol i'm doing some minor rea suspenson and some slicks pyro thi stall is amazing..
Old Sep 13, 2009 | 01:40 PM
94Z28rag's Avatar
Yeah don't waste our money especially if you've got stock heads/TB
Old Sep 13, 2009 | 05:55 PM
94LTZ's Avatar
I run ported and polished heads and a 52mm throttle body..
Old Sep 13, 2009 | 07:43 PM
86formula's Avatar
port the intake then, itll be worth it at that point. if you cant get the power to the ground it wont make any difference though
 Michael S. Palmer
Old Sep 13, 2009 | 07:51 PM
crookedbowtie's Avatar
I ported mine when I had it off. You can do it yourself and it doesn't cost anything..just match it to the gaskets and tr to be consistent on the blend. Worth paying money to have it done..probably not. Noticeable power gain...definitely not especially if the heads aren't matched. I did it for a future head upgrade, and believe that it may even hurt power without the heads matched. With that said I still couldn't resist and in my head it is "better".
Old Sep 13, 2009 | 07:54 PM
oliphant14's Avatar
stock suspension holds up fine tell about 450 then you need to start doing something
