Running a silicone coupler from MAF to TB...
Old Sep 13, 2009 | 06:33 PM
StealthFormula's Avatar
Default Running a silicone coupler from MAF to TB...
I'm so bored today that I came up with the idea to get rid of the ugly squashed stock piece that connects the MAF to the TB with something nicer that may even straighten out the air flow a tad. Figured a silicone coupler would do the job so I've found a couple on ebay. I'm away from home so I don't have an LT1 TB infront of me to figure this out.....The coupler I'm looking at has a 3.5" I.D. on one side which would fit perfectly to the MAF and the other side is a 4" I.D. Curious if when squished, would it fit the oval opening of our TB's?
Old Sep 13, 2009 | 06:39 PM
venom1997's Avatar
measure the diameter of your tb and if its 4 inches or really close it will work.
Old Sep 13, 2009 | 06:44 PM
cgEvan's Avatar
According to the guys that did the "over the radiator intake", you use that exact coupler for connecting the TB to the MAF.
RamAir95TA's Avatar
Just use a 3" Fernco sewer connector, available at Home Depot/Lowes/etc. Tons of people use them, including myself. Cost like $4.00.
You'll see it won't quite fit the throttle body when you first try to put it on - boiling it will soften it enough to stretch it over the TB.
Old Sep 13, 2009 | 08:35 PM
madball's Avatar
That coupler reducer will work. Your throttle body is a touch under 4" but it will squeeze on.
Old Sep 13, 2009 | 08:40 PM
madball's Avatar
siliconeintakes.com is a good place to order from too. I have bought couplers/clamps from there before. There prices are the best and there shipping time is super quick.
Old Sep 13, 2009 | 09:30 PM
Thanks alot guys I appreciate the help. I'll check out Home Depot and see if I can find that Fernco connector if not I'll just order one from that website.
Old Sep 14, 2009 | 06:32 AM
wht97ws6ta's Avatar
I just went to the local hardware store and got a 3 inch pipe coupler for 4 dollors. Works perfect. Its a stretch to get it over the TB to start wid but once the heat hits it it forms to it.
