mallory 685 box.
Old Sep 13, 2009 | 08:48 PM
TravisMcGill2000's Avatar
Default mallory 685 box.
Im thinking bout ordering one but have no idea how to hook it up. What is needed to work with opti? Anyone have a write up on how to hook it up. sorry if this seems like a stupid ?.. thanks alot guys
Old Sep 13, 2009 | 08:50 PM
I_Need_Land's Avatar
Old Sep 13, 2009 | 08:52 PM
make sure you wire that EXACTLY like the pic... im talkin... make sure you seperate the wires going from the icm to the coil just like in the pic, dont T tap them.
Old Sep 14, 2009 | 12:02 AM
gregrob's Avatar
Uhh, you dont just use the msd harness and plug it in?
Im confused as to what else you need to do ..
I just wired mine up this wknd but havent started the car yet.
Old Sep 14, 2009 | 06:29 AM
kcarlasc's Avatar
I was looking into the Summit box, which is a clone of the Mallroy I beleive, as gregrob said above, they just told me to get the MSD adapter... mush easier... of course have not ordered either yet...
Old Sep 14, 2009 | 07:34 AM
i have the summit box thats a mallory 685 knock off.
Old Sep 14, 2009 | 05:16 PM
so msd makes a adapter? If so that be alot easier.
Old Sep 14, 2009 | 05:35 PM
also can you advance timing with it or just retard
Old Sep 14, 2009 | 07:37 PM
i havent really played with it yet, but i dont think it can advance the timing.
Old Sep 14, 2009 | 07:52 PM
~BuMps AloT~'s Avatar
just get the msd wiring adapter makes it easy as heck!!!
Old Sep 14, 2009 | 08:02 PM
my car is on stock timing right now. How much power yall think i will gain na if get it bumped up some.
Old Sep 14, 2009 | 08:05 PM
litch2004's Avatar
the adapter makes thing easy as hell its all plug and play. it has two wires coming off off the box that plugs into the new adapter harness. Then the harness plugs into both of the coil plugs then it has one plug that plugs into only one plug on the coil.
It works great!!
Old Sep 14, 2009 | 11:11 PM
gregrob's Avatar
The Mallory can not advance timing.
Only retard.
It has a programmable start retard (to make it easier for the engine start).
And a high speed retard, that is activated via a 12V input. Such as for nitrous, etc
Old Sep 16, 2009 | 12:21 AM
litch2004's Avatar
this will explain it a little better.
Old Sep 16, 2009 | 12:50 AM
gregrob's Avatar
MSD harness worked perfect for me.
The Mallory box is badass!!
Old Sep 16, 2009 | 08:14 AM
DopdBrd's Avatar
MSD harness but you cannot use the same colored wires as the MSD box does. Here this will help
Mallory-----------------------MSD
Red --------------------------Red
Black-------------------------Black
Green------------------------White
Yellow-----------------------Orange
Old Sep 27, 2010 | 03:38 PM
355z28's Avatar
whats the harness part number your using for the 685? Im looking to install this shortly, but I cant seem to find it.
