lifter question.
Old Sep 14, 2009 | 06:05 PM
iroc1793's Avatar
Default lifter question.
i asked the end of last week about getting lifters for my engine, i ordered up the ls7 lifters. i was wondering if i should have ordered new pushrods aswell. i currently am running futral chrome moly pushrods, and 1.6 rr. do i need new pushrods or no?
another question, when installing the ls7 lifters do i need to let the lifters soak in oil before i install them or can i install them dry and they will pump up with oil, then go through and adjust my valves?
thanks guys, appreciate the help.
dan
Old Sep 14, 2009 | 08:21 PM
RamAir95TA's Avatar
dan
The LS7s are direct replacement, so they shouldn't affect your overall pushrod length. But, there have been reports that the LS7s have a deeper cup than stock and require a slightly longer pushrod. IMO, it's best to just measure.
Fact of the matter is, the LS7s already have oil in them from the factory. I lubed up the bores and rollers, popped them in, primed the oil system, done.
Old Sep 15, 2009 | 06:05 AM
iroc1793's Avatar
great thanks, ill double check them when i get them in the engine, and good to know that i can just put them in, i did a 460 with flat tappet lifters and they needed to be primed before hand, so thanks for the help!
Old Sep 15, 2009 | 06:58 AM
shbox's Avatar
Any new lifter should be soaked in a cleaner to remove sticky manufacturing lubricants. Then, you should soak them in oil.
