Thinking about another set of heads...
Old Sep 19, 2009 | 05:00 PM
94LTZ's Avatar
Default Thinking about another set of heads...
Right now i'm running the stock heads on my 94 z28 that have been ported and polished by a local guy that pretty good but probably not like llyod or A.I. I've been looking at a set of AFR, trick flows or A.I... It looks like i'm buying a custom grind cam from Lloyd and i have to switch my valve springs so i've been considering selling my haeds and cam set up i have now but not sure what to asy
Heads and cam specs- CC306 with about 6,000 miles, stock heads with port and polish job, Beehive 918 springs, cc locks, cc retainers, cc seats, and the heads were re surfaced before my rebuild 6,000 miles ago.. The heads still look brand new after being in the tank but how much do you think i should ask for this set up??
Also what heads would you guys reccomend if it's any of the brands i suggested or one that i didn't let me know.. Thanks
Old Sep 19, 2009 | 08:03 PM
JasonShort's Avatar
Moderator
You need to try doing a search on these questions. Cylinder heads are the most talked about engine component in this section of LS1tech.
