line lock and brakes
Old Sep 21, 2009 | 07:26 PM
fastfox's Avatar
Default line lock and brakes
i have 97 ss camaro head work big cam lots of work done to car. having problmes with brakes and line lock holding car. both of them push the car any no whats goinng are had this problem.
Old Sep 21, 2009 | 07:42 PM
RamAir95TA's Avatar
Make sure the brakes are bled properly.
Also, holding power is amplified at the track. If the line lock won't hold the car on the street, it will hold it at the track, due to the waterbox and lack of traction on the rear tires (assuming you're using a slick-type tire).
Old Sep 21, 2009 | 07:59 PM
fastfox's Avatar
want hold street are the track 16x9.5 rear tire with mickey tompson drag radial 2 the new ones
Old Sep 21, 2009 | 08:00 PM
RamAir95TA's Avatar
English and punctuation go a long way.
Old Sep 21, 2009 | 08:05 PM
fastfox's Avatar
sorry want hold on the street are the track,have the mickey tompson drag radial,on rear.
Old Sep 21, 2009 | 08:14 PM
86formula's Avatar
you didnt do much better there either, are you rolling into the throttle or kind of stabbing it? your better off stabbing it to get the tires spinning just make sure not to hit the limiter
Old Sep 21, 2009 | 08:18 PM
fastfox's Avatar
Cool
come thro the water box and hit it,then turn line lock on but it does not hold the car,just pushes it on the streets do the same thing but without the water.
Old Sep 21, 2009 | 08:21 PM
RamAir95TA's Avatar
Roll through the water box, stop. Apply the brakes HARD, then engage the line lock. If the brakes are properly bled and the solenoid is good there's no reason you should roll through it.
Holding on the street won't happen easily. Mine won't hold on the street but at the track it's fine.
Old Sep 21, 2009 | 08:25 PM
fastfox's Avatar
k thanks dude,will bled brakes this weekend,that's exactly what i do apply brakes then press line lock.
Old Sep 21, 2009 | 08:28 PM
RamAir95TA's Avatar
Make sure you bleed in order - 1. right rear, 2. left rear, 3. right front, 4. left front.
Old Sep 21, 2009 | 08:38 PM
fastfox's Avatar
will do dude thanks.
