Well I put the wideband on the car and you AINT gonna believe THIS!
She kinda fat, It stays at 11.3-11.4 until the shift and then will lean out to 12.1 for a second then back to 11.3.
I knew it was rich, but not THAT rich.
I gotta get Tunercats and get some mo POWA!
You have to have it all the way to the floor when you do air fuel testing on these cars or the fuel pressure regulator will mess with you big time and show very rich.
When you get ready to start tuning on it if you need help feel free to pm me, and i'll help you get it in shape. I'll have to have a copy of your tune first to figure out exactly why its so rich. I can also show you how to log the wideband through datamaster if you don't know that trick, its worth doing and will save you a bunch of brain damage.
Thanks a bunch, I calibrated the sensor per the instructions.
And it was WOT,1st gear roll 1/2 way through high gear. 2 times it read the same thing.
I will make sure I calibrated it right. Dont want to make a screw up like that.
I missed the boat on that one
Gizmo I understand, and will do just that per your instructions. I am a tuning newbie and it will be EASY to make a fatal mistake on this engine as it is 12.5 to 1 on pumpgas, dynamic is 8.8 I think it was.
I went out and re calibrated the sensor again and made two more runs, same thing, but now the lowest was 11.6. Cruise is nice and lean at 15 ish.
