Low miss... Stumped Help!!!
Old Sep 22, 2009 | 01:02 AM
sdotlog's Avatar
Exclamation Low miss... Stumped Help!!!
Ok, from 1k-2k car is missing. Was back firing intermitantly through the intake(what it seems atleast) till about 3k a couple times. Floored it once, rpms jumped up but car didn't respond to it as much as it should have. New coil, wires, plugs, tps. It was fine for a couple weeks until now?
Sucks as this is my DD, and moving further away from work now and definitely can't afford this thing to be down that much longer.
Old Sep 22, 2009 | 03:41 AM
TRANSAM GT4's Avatar
Did it throw a code?
Old Sep 22, 2009 | 08:50 AM
sdotlog's Avatar
ses stays on because i cant figure out the p0200. I'll scan it for codes today when i get the chance.
Old Sep 22, 2009 | 10:41 PM
sdotlog's Avatar
Scanned. No codes. Seems to run fine, then intermitantly would miss. I've unplugged sensors on the tb and maf. The only one that didn't raise the idle was the iac plug. Wouldn't that mean the iac is non functional?
Old Sep 23, 2009 | 11:03 PM
sdotlog's Avatar
still no code. still hesitates low rpms. putting in a new iac, checking plugs, and if nothing changes i guess i'll go ahead and get that opti unless anyone else has any ideas?
