lt1 injectors
Old Sep 22, 2009 | 06:47 PM
rutt71's Avatar
Default lt1 injectors
what size injectors shoul i run with bolt ons and 8lbs boost supercharged also any ideas of what a bone stock 95 trans am will run with drag radials and 150 shot wet?
Old Sep 22, 2009 | 08:32 PM
93Z2871805's Avatar
Veteran: Air Force
Doing the calculation using 500 flywheel horses, .60 BSFC, an 80% duty cycle at 43.5 rail pressure, 47.15lb injectors. SVO green top 42# on a gm system will make 45#.
By Brett Foote | 2026-06-04 05:00:17
