Tips for taking off header bolts?
Old Sep 24, 2009 | 02:48 PM
SlowestTransAm's Avatar
Default Tips for taking off header bolts?
I have a 94 TA with a LT1.
I'm on the last 2 bolts on the passenger side, the first and last bolts.
I took the alternator off and still cannot get to the first one.
Any tips would be appreciated, thanks!
Old Sep 24, 2009 | 03:33 PM
White97z28's Avatar
Magic... I find it's the easiest way to work on these cars.
Sorry I can't help more but it has been along time since I took mine off...
Old Sep 24, 2009 | 04:07 PM
bore.me's Avatar
Just took mine off. i think i used a 9/16" short socket with 1/4" drive and a long extension for the front one. Just try different combos of sockets/extensions/wrenches until you find something that works. The farthest back bolt can be reached from under the car, i think. I had to twist my arm into positions i didn't think i was capable of doing to make it work, so good luck!
Old Sep 24, 2009 | 04:08 PM
RamAir95TA's Avatar
If you go under the car, make sure you have goggles on. Rust + eyes = not fun!
Old Sep 24, 2009 | 04:56 PM
Yes...have found this out the hard way, thank god for contacts.
Old Sep 24, 2009 | 04:57 PM
93Z2871805's Avatar
Veteran: Air Force
Become double-jointed at the shoulder and elbow. I just use a short gear wrench.
Old Sep 24, 2009 | 05:13 PM
squeals99's Avatar
yeah i just installed headers yesterday on mine... best way i found was to basically sit on top of the motor almost and just work around in there... you'll get them!
Old Sep 24, 2009 | 06:36 PM
AChotrod's Avatar
use a small box end wrench worked great for me.
Old Sep 24, 2009 | 07:54 PM
00FlowCamaro's Avatar
x2. I was on top of the motor a lot to wrench everything in/out.
Old Sep 24, 2009 | 08:24 PM
stevo9389's Avatar
offset box wrenches (the ones shaped liek the letter "C") helpded me a lot especially with the back bolts. can buy a cheap set from harbor freight and grind down the outside for more clearance
Old Sep 24, 2009 | 08:44 PM
Al 96 Ram Air T/A's Avatar
Everything that was said above, and....
DO NOT FORCE a frozen bolt. It will either snap or strip out the threads in the aluminum. Use a torch to heat the the head...not too much, just enough to help.
Go slow...when you complete a manifold/header removal and install...you've graduated to the big leagues. It's one of the hardest things to do on our cars. That's why most of us do everything while we're in there (plugs, wires, etc.) I've done it twice now, and will NOT do it again. The next time, the next owner can do it...or I'm going to drop the engine out the bottom. It took me well over 30 hours to put my mid-length headers on, as I had to custom fab parts to make them work (i.e. dipstick tube, move and lengthen steering shaft, reroute brake lines, OTVC wires, etc.)
It's abig job my friend...but it;s worth it in the end.
