96 engine in a 95?
Old Sep 24, 2009 | 03:58 PM
Revson's Avatar
Default 96 engine in a 95?
I recently bought a 95 Z/28, with a blown head gasket. I was going to pull the motor out and go through it. Now a friend of mine has found me a nice LT1 out of a 96 Firebird. I know a 96 is OBD2 and mine is still OBD1, can you give me any advice on this? Is it just a matter of switching sensors over? Or are there bigger differences than that? Any advice would be appreciated.
Old Sep 24, 2009 | 04:05 PM
RamAir95TA's Avatar
Mechanically they are identical. All of the sensors are the same, except you'll need to use the 95 OBDI knock sensor. Should be a piece of cake.
Also, the 96 will have a provision in the timing cover for a CPS, which you can just leave unplugged - it's not used in OBDI PCMs.
