roller rockers
Old Sep 27, 2009 | 09:47 PM
vegasfbody's Avatar
can someone please give me a part number on some scorpion 1.6 nsa and sa
Old Sep 27, 2009 | 11:12 PM
stevo9389's Avatar
what lift ratio are you looking for and do you need 3/8 or 7/16 studs?
Old Sep 28, 2009 | 10:35 AM
vegasfbody's Avatar
i dont know my car is pretty much stock like i said before i will be camming it but nothing big the the brightest when it comes to specs of stuff more a body guy my self as for the studs 3/8 as thats stock right?
Old Sep 28, 2009 | 11:37 AM
gregrob's Avatar
3/8 is stock is yes.
I say go 7/16's.
1) Because studs are cheap
2) Because it doesnt change the cost of the rocker arm much, if at all usually.
3) Because valvetrain ridgidity is always a good thing regardless of the level of the build.
4) If you buy a quality lifetime-warrantied rocker, you can use them on a possible future build that would "need" them.
Old Sep 28, 2009 | 12:32 PM
kinglt-1's Avatar
^agreed! Buy something you can use down the road. Sa rockers are for bolton cars only imo. Nsa rockers w/ 7/16 studs should be mandatory for heads/ cam setups. If you can afford it, get the comp high tech stainless. This rocker will most likely outlive the car.
Old Sep 28, 2009 | 01:00 PM
stevo9389's Avatar
go here: http://www.flatlanderracing.com/scor...s.html#chevySB
you will need to click on small block chevy and it will give you part numbers for all the ratios for 3/8 and 7/16. unless you have had the heads worked to accomodate a higher lift i would not go over 1.5 ratio. you can go 1.6, i have seen it done, but depending on whom you speak with the stock springs (even on a stock cam) are being maxed out or dangerously close if you go with 1.6.
Old Sep 28, 2009 | 01:26 PM
kinglt-1's Avatar
Right, but he is planning on installing a cam, read his last post. Most guys run nsa 1.6's with 7/16 studs and guideplates cammed. Yes the springs will need to be replaced.
Old Sep 28, 2009 | 01:33 PM
BLWNLT1_T/A's Avatar
I got springs CC Springs and CC puchrods NIB I let go for 100.00 Shipped.
I bought some TFS heads and wont need them. Also got some ls7 lifters which in my case require a slightly longer pushrod.
Old Sep 28, 2009 | 01:35 PM
stevo9389's Avatar
i read his last post i just dont understand the relevance of you pointing that out. i wanted to leave nothing to assumption that he knew about the springs.
Old Sep 28, 2009 | 04:34 PM
vegasfbody's Avatar
so should i go with 1.5s cause im gonna be building my race motor on the side im going to keep this motor a very super streetable motor nothing crazy
Old Sep 28, 2009 | 04:40 PM
vegasfbody's Avatar
ok so i have decided like posted above that the motor i have now is gonna stay mostly all bolt ons and im going to be building a 383 on the side for now i want a set of rollers rockers for the bolt on motor so 1.5 3/8 good idea?
Old Sep 28, 2009 | 04:48 PM
  #32
kinglt-1's Avatar
no because you will have to sell those and buy nsa 7/16 for the 383. Buy the right rockers the first time imo. Get a set of 7/16 nsa 1.6's w/ upgraded springs now and transplant them onto your 383 when it's built.
Old Sep 28, 2009 | 05:09 PM
  #33
vegasfbody's Avatar
well im building an entirely diffrent motor on the side the motor in the car will stay how it is minus some things but the new motor will be w whole diffrent block (dart block) so im building a street motor and a whole diffrent race motor on the side so for the bolt on street motor good to go with the 1.5s?
Old Sep 28, 2009 | 08:06 PM
  #34
myltwon's Avatar
I run 3/8 SA rockers on my 383...then again I make peak power around 6k
Old Sep 28, 2009 | 10:35 PM
  #35
stevo9389's Avatar
1.5s are fine because they are the stock ratio anyway. if you dont plan on using them for another build then it might not be a great investment. 1.6s would have a greater resale value if/when you part out the current motor.
Old Sep 29, 2009 | 12:27 AM
  #36
93Z2871805's Avatar
Veteran: Air Force
Procomp has some shaft mount rockers for like 242.99(alum) 264.99(steel) from jegs. PN 2342 for aluminum and 2347 for steel 1.6 ratio.
Old Sep 29, 2009 | 12:01 PM
  #37
96lt1m6's Avatar
for the money spent 1.5 rr would serve no benefit at all, atleast 1.6s will give more power for the same money!
Old Sep 29, 2009 | 12:09 PM
  #38
CARFREAKS's Avatar
I agree go with a 1.6 or dont do it at all...
Old Sep 29, 2009 | 12:35 PM
  #39
kinglt-1's Avatar
Why spend the money on a set of 1.5 roller rockers? The stockers will do the same thing on the stock cam. There is no significant gain, unless you increase the rocker ratio to get more valve lift, hince 1.6! Spend the money on 1.6's with atleast an ls6 spring(cheap), or don't do it at all imo.
Old Sep 29, 2009 | 12:44 PM
  #40
AChotrod's Avatar
Sounds like a waste of money to me if your building a 383.
Why not buy something once and just switch it over when you do the swap. I recommend the Comp High Tech Stainless rockers as well. Also 1.5s are a complete waste of money on either set up IMO.
