malfunction indicator lamp code 95 trans am help please
my 95 trans am is having trouble starting on a cold start i have to try 2 or 3 times to get it to start and then it finally starts. only code is malfunction indicator lamp code. let me know if you have had this problem or anything that could help thanks in advance
so the SES isn't on? does the car run rough once it starts? i had a problem where my car would not start easily if it sat for more than a few hours after i drove it last and it would run kind of rough once it started. no SES codes and i failed emissions during that time for too much NOx (i think it was NOx) turns out my intake elbow was torn and i was getting too much unfiltered air.
yeah i just replaced my intake elbow so idk. but once it gets started it runs fine. o hope that guy with ricky bobby in his sig knows something about it because he seems pretty smart with lt1's
