Lt1 355 forged pistons?
Old Sep 27, 2009 | 09:55 PM
SPRAYED Z's Avatar
Default Lt1 355 forged pistons?
As the title states Im looking to do a 355 build with forged flat tops ONLY because the budget is real low. So can someone give me part numbers for a mahle piston that will allow LLoyd Elliot heads and cam. Also Im looking for part numbers on the splayed 4 bolt main caps and arp bolts.
Arp rod bolts #
mahle piston # or better yet a lightweight piston #
thanks, Tom
Old Sep 28, 2009 | 07:46 PM
robsquikz28's Avatar
I think if you search you might find something out there.
Old Sep 28, 2009 | 07:56 PM
myltwon's Avatar
if you're on a budget why are you converting to 4 bolt main?
Old Sep 28, 2009 | 07:58 PM
1badzee's Avatar
a 2 bolt will be fine.. My buddy is spraying a 250 on a 2 bolt motor going 8s. Granted, it's a ford.
Old Sep 28, 2009 | 08:12 PM
myltwon's Avatar
people definately underestimate the 2 bolt mains. honestly the money spent on that could get you a nice 3.75" crank prolly
Old Sep 28, 2009 | 08:17 PM
Come on guys that still dont answer his question of what the part numbers are for the parts he wants..lol
Old Sep 28, 2009 | 08:28 PM
myltwon's Avatar
Rod Bolts
113-134-6005 ARP High-Performance LT1/LT4 Connecting Rod Bolts for Powdered Metal Rods $62.99 (Thunderracing.com)
Main Bolts (not sure which is right but imagine you need the "splayed" version)
113-234-5602 ARP SBC Main Stud Kit 4-Bolt Main, Large Journal with Straps & Splayed Caps $82.99 (Thunderracing.com)
113-234-5601 ARP SBC Main Stud Kit 4-Bolt Main, Large Journal with Windage Tray $94.99 (Thunderracing.com)
if you want to locate the parts on summit's website just take off the 113- part at the beginning of the p/n
Old Sep 29, 2009 | 12:07 AM
skinnies's Avatar
Originally Posted by myltwon
people definately underestimate the 2 bolt mains. honestly the money spent on that could get you a nice crank prolly
and people understimate the stock crank, I was just shy of 900 crank on a stock crank with no problem, others have made a lot also(300+ shots).
If you want a real budget, use the stock rod and trw piston on a stock bore(assuming you have a good block) and just hone it. Stock main bolts, stock rod bolts, new bearings/rings, cheap budget shortblock. Just make sure to get a good balance job.
Old Sep 29, 2009 | 12:11 AM
myltwon's Avatar
nah wasn't trying to downplay the stock crank, it's a great piece. just saying if he has the money to blow on a 4 bolt main he could get a decent 3.75" stroke crank in there just as an example of the kind of money he's looking to spend on something that's unneccessary
Old Sep 29, 2009 | 09:31 AM
Corey @ Clayton Racing's Avatar
MAHLE sbc250030f05 flat top 4.030 bore 6" rod 429 grams
MAHLE sbc125030f05 6.125 rod 406 grams
MAHLE sbc550030f05 5.7 rod 464 grams
all with stock crank
Old Sep 29, 2009 | 11:13 AM
MAHLE sbc550030f05 5.7 rod 464 grams for the stock crank will be just fine!!!
Old Sep 29, 2009 | 11:18 AM
djjab57's Avatar
Sbc250030f05 Edit sorry these are for the 6 inch rod
Old Sep 30, 2009 | 09:38 AM
Thats what I have them listed as?
