Ok another cooling problem 94 z28
first, you need a working temp gauge to know what's going on. So unless the coolant is not getting over 100F after idling for 20 minutes which is not possible, you either have a bad coolant sensor on the block or a broken connector or wire, or at worst a bad gauge in the dash.
with some kind of working temp gauge, if coolant temp isn't reaching 180F or whatever LT1's run at, then it's most likely a stuck open thermostat. And if it's overheating it can also be a stuck closed thermostat... along with debris in front of the radiator, clogged radiator or very old coolant that was never changed, or massive air pockets in the cooling system.
if you overheated the crap out of it, then it's possible you warped the heads in which case you will need new head gaskets and also have to machine the heads flat, but before coming to that conclusion you should have the cooling system pressurized and find out if there's a leak. You can also pull the spark plugs and check them for signs of water/coolant in the combustion chamber.
Take a picture of it and show exactly where the leak is.
I have an LS1, and we have two rubber hoses clamped to the passenger side of the water pump, then they both run back to the firewall. One of mine started to get a bulge in it about 3 months ago (11+ yr old factory original hose). I took the clamp off, took a razor knife and cut the bulge out, about 1.5 inches....then slid the hose back on, good as new. Screw changing that pain in the *** heater hose.
