a few ?s on my 355 built.
Old Sep 28, 2009 | 10:56 PM
TravisMcGill2000's Avatar
Default a few ?s on my 355 built.
Im pullin my motor at the 1st of year and wanted some opinons. Its gona be a 355 with speed pro forged pistons, scat forged Ibeam rods,stock crank. With arp rods and main cap bolts. The new trickflow heads, le custom grind cam and ported intake.Ls7 lifters,hardened pushrods,gm opti, plus ive already got all the supporting mod... what injectors should i run? Plus whats a good timing chain and oil pump to buy? Are there anything else im missing? thanks sorry for the long post
Old Sep 28, 2009 | 10:58 PM
how hard could i turn these motor safely? Could it handle a 150 shot also?
Old Sep 28, 2009 | 11:55 PM
myltwon's Avatar
how much power are you aiming for? custom cam and heads don't tell the whole story but I'd say a 36# injector should fit the bill for pretty much what you're planning
Old Sep 29, 2009 | 01:37 AM
robsquikz28's Avatar
Id say 7000 max with the stock pcm and make the most of the power band. Just make sure you have arp bolts everywhere that counts and a good machinist.
Old Sep 29, 2009 | 08:22 AM
myltwon's Avatar
and a damn good balance
Old Sep 29, 2009 | 03:22 PM
I aiming for 400rwhp.. Im going with around 11.5.1 compression. Gona run the trickflow 185s heads. the cam shaft will be something around a 230/236. the car is gona be a 70% drag car. 30% street. this is gona be my first build. so any advance is welcome lol.
Old Sep 29, 2009 | 03:25 PM
i planning on doing all arp hardware. The bottom end will be balanced for sure. what are some good brands for the 36lb injectors? should i stick with the stock balancer or buy a ati
Old Sep 29, 2009 | 07:58 PM
myltwon's Avatar
well the stock is actually a "dampner" unless you're planning on a pretty serious build stock should be alright
30# svo's worked for my 12:1 383 making a little under 400rwhp. for a decent brand I'd say trying to find pretty much any Ford/SVO injector as they are fairly high quality, not expensive, and pretty common especially 39# (03-04 Cobra) and 42# (Lightning)
Old Sep 29, 2009 | 09:49 PM
AChotrod's Avatar
Racetronix Delphi 37lb injectors ! But I think if 400 is your goal a set of LE2s with that cam would be close
