still having problems
Old Oct 1, 2009 | 02:45 PM
kalebm22's Avatar
Restricted User
Default still having problems
i have changed teh oxegyn sensors, maf sensor, optispark, fuel pump, computer tunes. and computer.
but i am still haveing a sputtering problem and my afr gauge shows its going lean when im having the problem. what could cause it to do this that i havnt changed yet?
Old Oct 1, 2009 | 03:00 PM
trippinholyman's Avatar
clogged injectors? try running some seafoam through the tank. hows your fuel pressure? not enough fuel getting to it, so maybe theres a leak somewhere or something.
Old Oct 1, 2009 | 03:04 PM
kalebm22's Avatar
Restricted User
well i changed teh injectors too, still having the problem. for some reason my fuel pressure gauge stoppeed working so im not sure on the fuel pressure. but i only have teh problem after the car gets up to operating temperatures
Old Oct 1, 2009 | 03:09 PM
jarretthise's Avatar
icm or coil it sounds like.. sounds like the coil or icm is breaking down.. when they go bad or get old the particles breakdown in them when hot.
Old Oct 1, 2009 | 03:12 PM
kalebm22's Avatar
Restricted User
i have and msd coil on it that i put on not long ago, but how would one of those things make the car run lean?
Old Oct 1, 2009 | 03:20 PM
well if the icm is breaking down then your car is going rough.. causing your car to have a misfire therefore reading lean and not really actually having a fuel problem.. had this happen on a 3.8 i worked on..
Old Oct 1, 2009 | 04:38 PM
myltwon's Avatar
hook up a fuel pressure gauge and check for vacuum leaks (also post maf leaks)
Old Oct 3, 2009 | 01:03 AM
kalebm22's Avatar
Restricted User
well i switched my icm and coil with a friends and i still had the same problem, i also just replaced the manifold pressure sensor and the air temp sensor. i think i will be able to check the fuel pressure monday.
