Heater Core Restrictor Valve, Removal with EWP?
Can I safely remove the heater core restrictor valve since I have a Mezierre HD EWP installed? I believe that the restrictor purpose is to reduce flow to protect the heater core. The Mezierre should not turn as high of rpms as the stock mechaincal pump. Thoughts?
This is the second restrictor I have installed. The crappy plastic ones do not last and tend to leak.
Thanks
Thanks
Actually, the restrictor is to prevent overcooling via the heater core. The idea is that in extremely cold weather the heater running will prevent the motor from coming up to temp since the heater is on the bypass side, so it runs the real risk of overcooling the motor during the warmup phase. The restrictor is to make sure the motor comes up to temp as quickly as possible and due to the size of the heater core/piping it allows for adequate hot coolent flow to provide ample heat to the interior/defroster.
I may add that the reason the piping isn't smaller is because the higher volume of coolent has better thermal stability.
Mine broke when I was doing my H/C/I install, Just cut the hose and conected the two, Zero problems so far 3k since, although I am in the middle of deleting my complete hvac system.
Thanks
IDK. I've never heard that expanation before.
Me neither.
Well I decided to delete it today. I was in Autozone for something else and I picked up some heater hose while I was there. I now just have one solid piece 3/8th's hose going from the water pump housing to the heater inlet. I guess we'll see what happens. If anyone thinks this is a bad idea please let me know. I'm mostly concerned about the heater core. I'll keep an eye on the temps. At least the leak is gone. Back to the LSU/Georgia game. Go Tigers!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
not heard about the over cooling thing but can understand that point. My "understanding" on the restrictor valve is to keep pressure down going to heater core since it's core pipe is small and to much pressure can cause leaks in the heater core.
GM or any car manufacturer will not spend $.02 on a part if they don't have to so my sense is it has a valid purpose.
YMMV
YMMV
