call me crazy but..
Old Oct 3, 2009 | 12:00 PM
xdanny510x's Avatar
Question call me crazy but..
i seen a ebay turbo kit . that i am tempting to to buy.. but i was thinking along the line of getting a different turbo. but keeping the piping.. and stuff. What would be the drawbacks if i do get it and toss the turbo and get a better brand turbo..and keep all the piping?
JDM'S T3/T4 Turbocharger with 3" Filter!!
Turbine Turbocharger
Oil cooled only
6 blade propeler
Compressor Specs :
3" Compressor Inlet
1.990" or 50.55mm Minor
3.000" or 76.2mm Major
Compressor .50 A.R.
Compressor 57 Trim
M12 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
2.25" Outlet
Turbine .64 A.R.
Turbine 76 Trim
2.207 " or 56.06mm Minor
2.567 " or 65.2mm Major
Exhaust Outlet Flange with 5 bolt design
Can modified to use external or internal wastegate.
JDM'S T3/T4 Turbo Oil Feed Line !!
Made Out of High Quality Aluminum
Improves Engine Oil Cooling for all Engine types
Length : 36"
1/8" Adapter NPT Male Fitting for the Block
Comes with all accessories needed.
JDM'S T3/T4 Turbo Oil Return Line !!
Oil Return Line made for turbo
Helps circulate oil from the turbo to the oil pan
All components are included for fitment
Fits on all turbos
Only works on metal oil pans only!
JDM Manual Turbo Boost Controller !!
In order avoid replacing wastegate springs, which only give a fixed increase, which is not adjustable, a boost controller will be the most cost
effective solution.
Allows adjustable boost psi settings, light weight design to be mount under the hood. Hardware is included
Universal fitment and great for all Turbo applications
Easy to adjust from 1-30PSI
Professional Installation required
JDM Blow Off Valve with Adapter Pipe!!
Direct Bolt-On For All Turbo Application With Flange
Universal Fitting Kit
This Blow Off Valves Are Easily Adjustable To Prevent Both Premature Boost Leakage And Compressor Surge
Both Premature Boost Leakage And Compressor Surge.
It Can Hold Up To 1200HP Or 25 PSI Of Boost Pressure
Professional Install Suggested
Comes with 2.5" Adapter pipe made for bovs
JDM'S 2" Turbo Boost Gauge & Air/Fuel Gauge
52mm diameter = 2inch universal fitments
Luxury Chrome trims framing
Dark Tinted face for stealth JDM looks.
LED lightings allow great visibility during day and night
12v gauge, light weight abs plastic finish
Features White numbering and Red needles
JDM'S Universal Starter Turbo Piping Kit
Intercooler Piping are CNC Machine Mandrel Bent (Jp Design)
Made From High Quality 6061 Aluminum Material with chrome finish
Extra Thick Piping and Increased Air Flow
Light weight design. Made from Aluminum.(Increase 10-20 HP).
PSi Drop under 0.2. Other Intercooler usually drop 10Psi Some are More
Comes with Turbo Pipes, T Bolt clamps and Couplers
JDM'S 31"x11.5"x3" Turbo Intercooler
Tube & Fin Design
Light weight designed. Made of Aluminum.(Increase 10-20 HP).
All TIG Welded 6061 Aluminum
Max PSi is 30 Up to 400HP
Core Size: 28"x11.5"x3"
JDM'S T3/T4 Turbo Downpipe Flange
Made out of High quality of Aluminium Material
Made from 100% SUS T-304 Stainless Steel
Used to fit with any pipe to make a custom downpipe to fit your car.
JDM'S 38mm Turbo Wastegate with Flex Pipe
All Stainless Steel hardware
Mating weld flanges are 304L.
17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resist "relaxing" at temperature to 900F (483C).
High temperature silicone reinforced actuator diaphragm.
High temp alloy is used for valve and 347SS valve housing will offer longer product life compared to competing designs.
External wastegates are commonly used for regulating boost levels more precisely than internal wastegates in high power applications, where high boost levels can be achieved.
Comes with a spring around 7psi
