So I am completly stumped
Old Oct 3, 2009 | 12:03 PM
96Formula6spd's Avatar
Default So I am completly stumped
Hey guys I am out of ideas. My rebuilt engine should run but it does not. Its not running on cylinders 2,3,6,and 7. This is my list of stuff I have checked and everything has passed.
-Plug wires
-Plugs
-Injectors
-Rockers
-Timing marks on the chain
New parts Include
- Gm Ac delco Optispark
- New plug Wires
- New plugs tr55s
- Rebuilt Engine
- New ICM and Coil
Today I went out and checked the timing by bringing each cylinder to top dead center and checking the rockers. I also was checking and could feel that the piston was at the top. I would also check my rockers and they were both down since the cylinder should be firing. So I am completely stumped. I think I am towing it so a shop and let them look at it. Just for a last chance anybody have any ideas?
Old Oct 3, 2009 | 01:56 PM
the_merv's Avatar
Have you tested each of the Wires with a Spark Tester to determine that they are not firing?
I was just wondering..if you have Bent Valves then it's won't fire well either. Did you do a Compression Check?
Regardless if it's a major problem I would take it to a different shop than the one that re-built it, and make the first shop pay for it.
Old Oct 3, 2009 | 02:55 PM
Well I might have found my problem. We will find out in the next 1 hour. Anyways I was changing the oil when I found on of my grounds that sit on the coil is completely off. Does any one know what those grounds are for?
Old Oct 3, 2009 | 03:26 PM
Green3spd's Avatar
You def need to check all the grounds on car.
You can find them all here..
http://shbox.com/page/index.html
K Mack
Old Oct 3, 2009 | 04:31 PM
the_merv's Avatar
I'd re-connect that ground.. that is definately something important, and may be the cause of your problem.
Old Oct 3, 2009 | 05:27 PM
Well it was just the lighting strap so no change. Its going to a shop this week. I have had nothing but 7 months of straight trouble from this car. I had the engine rebuilt this 2.5 months ago and about a week after i got it back I have had this issue from the car.
