LT1 vs LT4 intake
Here is a picture GIZMO posted some time ago.
http://i85.photobucket.com/albums/k5...1/DCP_1456.jpg
If you have a head(LT4 or aftermarket) with a huge port that needs a huge manifold port I suppose ported it could be worth something.
Most people get carried away though. bigger is NOT necessarily better.
doubt its worth buying an LT4 intake over a LT1 intake though. if you have an LT1 intake now, just have it ported if you need more flow. if you already have a LT4 intake, theres no point in switching to a LT1 intake
The LT4 manifold is internally the same as the later LT1 intakes been covered MANY MANY times but the ignorance persists.
like i already said, i never measured the intake manifold port, but i do know my LT4 heads had a slightly taller intake port in the cylinder head. what i had to do was switch the intake gasket to the "777" gasket and port match the LT4 intake manifold to the new gasket and cylinder head port to get everything to match up
i think most everyone on here knows the head port on a LT4 is higher at the top than a standard LT1 port. whether i said "raised" or "taller", im sure everyone knew what i was talking about. seems like nit-picking to me
Every indication is that the Edelbrock parts are not worthwhile. I would blame that more than the LT4 designation they put on them.
Their own flywheel dyno numbers are lower than what can be expected from a good ported gm LT1 heads setup makes at the tire.
