timing set and oil pump
Old Oct 4, 2009 | 04:04 PM
TravisMcGill2000's Avatar
Default timing set and oil pump
whats a good timing set and oil pump for a mild 355
Old Oct 4, 2009 | 04:18 PM
shbox's Avatar
If you are still using your 1994's non-vented opti, you are pretty much stuck with a stock timing set. A Melling Select 10554 pump is a good one. Add a GM high pressure spring to it.
Old Oct 4, 2009 | 04:59 PM
thanks man.
Old Oct 5, 2009 | 04:04 PM
Whyrun's Avatar
I got a brand new moroso pump with all steel drive shaft if your interested 50.00 plus shipping
