Any direct port Lt1 users in here?
Old Oct 3, 2009 | 12:47 AM
waltsfastz's Avatar
Default Any direct port Lt1 users in here?
im tring like hell to figure out how to mount 8 fogger nozzles in a Stock Lt1 intake and get them to clear the valve covers. Anyone using a 90 degree nossle and doing this. Ive seen some pics using the strait nozzels but I hate to spend another 500 bux on nozzels. any suggestions,,,Pics?
Old Oct 3, 2009 | 08:06 AM
andysc's Avatar
You could go underneath for the stealth look and go underneath the manifold. Saw one for sale about 2-3 weeks ago, and it was badass. That's how I am gonna do it when I go with the squeeze.
hth
andy schuck
Old Oct 3, 2009 | 09:08 AM
N2OMIKE's Avatar
Old Oct 3, 2009 | 09:47 AM
jville's Avatar
Thats sic^ would def want to bench test is over and over tho just make sure no leaky leaky before you seal it up but the cleanest setup i've seen.
Old Oct 3, 2009 | 10:31 AM
waltsfastz's Avatar
That is sweet but It would be a pain in the *** to change jets. But a damn good looking setup
Old Oct 3, 2009 | 05:02 PM
SoxXpupPeT's Avatar
yeah. just dont change the jets that often haha :p thats insanely sick! thats the only way id run n2o
Old Oct 3, 2009 | 08:10 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
try these
or
Old Oct 3, 2009 | 08:40 PM
forgedlt4's Avatar
here was my mess that i used to run. it was not pretty, but it worked.
Old Oct 3, 2009 | 09:32 PM
James Montigny's Avatar
Originally Posted by N2OMIKE
Doesn't that cause problems with oil in the PCV?
Old Oct 4, 2009 | 07:51 AM
waltsfastz's Avatar
Originally Posted by Ray@Nitrous Outlet
try these
or
Are these 90 degree nozzles? If so thats kinda what I had in mind. If the nozzell is not exactly 45 degrees to the runner will that hurt anything?
thanks a lot for the pics fellas
Old Oct 4, 2009 | 10:57 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
the top one is using the NX vortech and the bottom is the NX Shark nozzle
Old Oct 4, 2009 | 03:11 PM
BADMOON's Avatar
I hope to be runnin the NX vortech soon as I save up some more pennies so I can send this car down to you.
Old Oct 4, 2009 | 04:18 PM
itSSlowZ28's Avatar
[QUOTE=N2OMIKE;12311497]
QUOTE]
that looks absolutely sick. but your solenoids are going to be a long way from the nozzles...
Old Oct 4, 2009 | 07:08 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I have some pictures of a similar stealthy setup I have saved on my other computer. The guy was selling it on Ebay and I saved them. I'll post them up tomorrow. The only thing I've wondered about that sort of setup is if you can fit the PCV cover back on. I guess you just reroute the PCV system into a catch can instead of the cover?
Old Oct 5, 2009 | 06:58 PM
waltsfastz's Avatar
im going to be running an EVAP(think thats whats its called) so I wont be using the PCV setup.
How critical is it that the nozzel outlet is the same angle as the intake runner?
