low coolant light
Old Oct 4, 2009 | 05:43 PM
musclehead's Avatar
Default low coolant light
The low coolant light came on in my 95 formula so i replaced the sensor and the light is still on, what gives?
Old Oct 4, 2009 | 05:53 PM
1994formulalt1's Avatar
um it might be low on coolant...
Old Oct 4, 2009 | 06:37 PM
92camaroguy's Avatar
Yeap would have been the first thing I would have checked.
Old Oct 4, 2009 | 10:04 PM
tonskiguy's Avatar
Now, you should not be judging a guy by his User Name.
Old Oct 4, 2009 | 10:58 PM
slingshot928's Avatar
I would unplug it and the light will go out....just remember to check the coolant regularly.
Old Oct 4, 2009 | 11:14 PM
the_merv's Avatar
Veteran: Air Force
Old Oct 5, 2009 | 06:17 AM
musclehead's Avatar
haha you guys are real funny. I check the coolant daily and it is never low.
Old Oct 5, 2009 | 07:41 AM
the_merv's Avatar
Veteran: Air Force
Probably have a short in a wire.
Old Oct 5, 2009 | 11:30 AM
bleed all of the air out of the system then and see if it still comes on
Old Oct 5, 2009 | 11:47 AM
tonskiguy's Avatar
Seriously, trapped air can cause this, and the syatem can be hard to bleed. I usually jack the car way up in the front, run it, burp it, repeat as needed.
Old Oct 5, 2009 | 12:12 PM
the_merv's Avatar
Veteran: Air Force
That is the one thing about the LT1 that is tricky..to bleed that Reverse Cooled System.
Old Oct 5, 2009 | 02:09 PM
slow96z's Avatar
I agree with unplugging it, first mod I've done both on the Camaro and Trans Am.
Old Oct 5, 2009 | 09:01 PM
TX02ramair's Avatar
x3 unplugging it, remove it and Clean the sensor and try it again, Replace the sensor
