Car wont start
Old Oct 5, 2009 | 06:01 PM
bowtie_racer's Avatar
Default Car wont start
Well I get off of work this morning after working 3rd shift, my car (its a 95) just cranks but wont start. I get a ride home so I can get some sleep. Then later I go back and it starts right up and dies, and just cranks again. I haven't check for spark yet or fuel, Im gonna borrow a buddies fuel pressure gauge and check that and check for spark. Any ideas why it wouldnt start then 5 hours later it did and then just died, and now wont start again?
Old Oct 5, 2009 | 07:05 PM
Any ideas?
Old Oct 5, 2009 | 07:10 PM
mcalus's Avatar
I am going to guess, I had a similar problem it was one of my coil packs went bad.
hope it all works out for you.
Old Oct 5, 2009 | 07:46 PM
sepno77's Avatar
most common problem would be a failed opti or fuel pump
Old Oct 5, 2009 | 08:45 PM
Would a opti work intermittently like that?
Old Oct 6, 2009 | 08:07 PM
It is getting spark. I changed the fuel filter hoping that was it, unfortunately it wasn't. I dont hear the fuel pump coming on so im assuming thats what it is. Still need to test it though. If that is the case which aftermarket fuel pumps would you recommend and which ones should I avoid?
Old Oct 6, 2009 | 08:20 PM
sepno77's Avatar
Originally Posted by bowtie_racer
It is getting spark. I changed the fuel filter hoping that was it, unfortunately it wasn't. I dont hear the fuel pump coming so im assuming thats what it is. Still need to test it though. If that is the case which aftermarket fuel pumps would you recommend and which ones should I avoid?
what test have you done so far?
Old Oct 6, 2009 | 08:33 PM
Well i did the basic spark plug wire to header spark test, theres spark (hopefully enough) I just know I dont hear the fuel pump coming on. I guess I should test the relay first. I still need to get a gauge and check fuel pressure.
Old Oct 6, 2009 | 10:44 PM
sepno77's Avatar
well you also need to get a om tester and test the opti harnes i think its a and d and both those need to be at 10volts w/ key in egn. also should test ign. fuse, and ground on the coil.
Old Oct 11, 2009 | 06:24 PM
I got it running today! It was the fuel pump like I thought. Thanks everyone for your help and suggestions.
Old Oct 15, 2009 | 04:17 PM
SPLATT's Avatar
put a new pump in?
Old Oct 15, 2009 | 07:00 PM
Yeah!
