cam wuestions
and how would i install it do i have to degree the cam or can i put it in there just anyway? this is my first cam swap on an lt1 car whoudl i take the motor out or remove the radiator and condeser
Also by the way your located in tokyo?
i woudl be gettting the springs lifters and rods to go with the cam an dthen gettign it tuned so woudl it then hodl it withough becoming a bog
i post what i am basing it off of
Eagle 4340 SBC 4.000 Crank for
LT1 one piece RMS
Callies Compstar 6.000 SBC Rods W/ ARP 2000 rod
bolts W 2.000 Big Ends
Wiseco Custom Pistons
Wiseco GFX Piston Rings
ACL MS909 H Main Bearings for 350 SBC
ACL CB 663 H Rod Bearings for 2.100 SBC
Chamfered Race Bearings
Durabond CH 8 SBC Cam Bearings uncoated
Eagle 400 SBC Splayed Caps 18 degree
ARP 4-Bolt Main Studs without windage tray for SBC
Freeze plugs kit and Misc
going for a 408 lt1 woot woot
The cam is a little much for a 350 IMO, for a 408 sure. In a stock bottom end car it would work well for the individual interested in a very strong top-end and willing to sacrifice low-end power and drivability so a not so great choice for a daily. When I was 16 all I wanted to do was stuff the biggest cam in my car that I could find. I wrecked the damn thing so that was a no go and probaly good because it would have been a mistake. I did my research for quite some time and about 2 or 3 years later I got another LT1 and put a nice 224/230 in it and it was great all around, sounded good too.
You can line up the chain dot-to-dot and be ok but the best way is to use a degree wheel. When I put my cam in I just did the dot-to-dot method and all is well but I recommend and will next time do it right with a degree wheel. If your the slightest bit off with dot-to-dot you could throw things off and slap a valve or two so if you do it that way make sure you have it lined up the best you can.
Edit: post #4 now fixed
In all reality, your enthusiasm is great, but you will be getting in way over your head for a 16 yr old looking for a ride to school. Not to mention your parents may have to burry you before you finish college. The motor your peicing together is for an NA LTX shootout car, not a replacement for a school bus. Not hating, but thats my .02......
i understand. what i failed to mention that if i do build the 408 i would be buying soem afr heads and it woudl not be driven aroudn alot.
and about me beign burried it can happen in a crappy 4 cylinder right??
and i woudl probally go with a diff cam with that build and just keep this one put it in my daily when i blow it up
im from texas also
