A4 iss
Old Oct 8, 2009 | 05:00 PM
Hawk40's Avatar
Default A4 iss
took the hawk on an errand a few days ago across down during rush hour..car ran perfect until i was almost back home...(about 30 miles in an hour and half of traffic) when the car started shaking a little under acceleration ...the car would also shake some while i was sitting still with my foot on the break..car in gear..the trans was also revving much higher before finally shifting..this is under normal driving. as far as the hesitating shifts, my first thought was low fluid...i checked it..fluid was clean and full. who's got ideas as to what it might be?
ps...car runs fine with transmission out of gear so its def trans.
ps ps...i may have found a good deal on a T-56 to drop in haha...still..i'd like to fix this first. or least have an idea what the problem is.
Old Oct 9, 2009 | 03:26 PM
red-_-z28's Avatar
check TPS (Throttle Position Sensor) its located next to the throttle body. I know it sounds weird but TPS's can do a bunch of crazy **** to your car. Trust me on this one!
Old Oct 10, 2009 | 11:27 AM
Hawk40's Avatar
wouldnt TPS impact the idle as well? it revs fine when its not in gear...
Old Oct 10, 2009 | 11:46 AM
the_merv's Avatar
Veteran: Air Force
Sounds like it's slipping..you'll need a rebuild.
T56 is a definate fix..I've killed too many Auto's to deal with that crap..
Old Oct 11, 2009 | 01:30 PM
Hawk40's Avatar
thanks merv...would the slipping occur all of a sudden though? like i said it drove fine all day then just all of a sudden started as i was pulling through my neighborhood
Old Oct 11, 2009 | 01:35 PM
pyro719's Avatar
The vibration your feeling is most likely warped frictions and steels inside the trans. Time for a rebuild. Did you have a cooler installed?
Old Oct 11, 2009 | 04:05 PM
the_merv's Avatar
Veteran: Air Force
Yea..pretty much how mine went.
Old Oct 11, 2009 | 09:00 PM
Hawk40's Avatar
ugh..well this sux...whats a decent rebuild cost? nothing too hardcore..but not backyard either..
if its over a grand, i'm thinking i might just take this as an oppurtunity to do a T56 conversion
ps..pyro-->..no cooler installed..bone stock tranny
Old Oct 12, 2009 | 01:30 AM
the_merv's Avatar
Veteran: Air Force
It depends on what type of re-build you want.
Old Oct 12, 2009 | 02:22 AM
earl lee's Avatar
If your gonna rebuld it might as well do it right which will be more then 1k, prolly 2k for a fully built one, might as well do the T56 swap if you dont want any auto anymore.
Old Oct 12, 2009 | 11:03 AM
LT1 POWAH's Avatar
My trans gave out just like yours did. It was fine then all the sudden it would bounce off the limiter under hard acceleration and would rev up with out it going any where. I took the opportunity to swap in a T-56. Never looked back.
