C16 Fuel Question
Old Oct 10, 2009 | 04:58 PM
SoxXpupPeT's Avatar
Default C16 Fuel Question
Would it be safe to run in my car ? its fully rebuilt and has an Ion tune on it. would i run the risk of damaging anything like O2 sensors or anything like that if i ran some? thanks
Old Oct 10, 2009 | 05:32 PM
stevo9389's Avatar
leaded fuel is bad for them and catalytic converters. if you dont mind replacing O2s shortly after then knock your socks off.
Old Oct 10, 2009 | 05:56 PM
ThreeHonks's Avatar
Waste of money IMO
FYI - You will need an open loop tune if you want to run leaded fuel
Old Oct 10, 2009 | 07:46 PM
SoxXpupPeT's Avatar
its a 94 so would i not have to worry about it open loop because its OBDI ? my friend who gave me some for free said it wasnt leaded. i made sure to find out because i know leaded fuel ruins O2's
Old Oct 11, 2009 | 07:47 AM
ThreeHonks's Avatar
No. you must mean that OBD-1 does not have rear o2's (which is correct). It still has fronts which would be ruined and cause the car to run poorly. Any competent tuner can tune your car in open loop, so you can remove the front o2's.
To be honest, I'm not sure if C16 is leaded or not. But there is also the possibility that it is not sensor safe due to other contents
Old Oct 11, 2009 | 08:04 AM
GIZMO's Avatar
I wouldn't run it. I think that you would be faster on pump gas. Something like C-11 might pick you up a little. Be prepared to replace your O2's.
Old Oct 11, 2009 | 11:02 AM
LS1 SPEED's Avatar
no need especially if not tuned for it
We use Denso 02's and they seem to have a pretty good life with leaded fuel. They have been in my car for awhile and my brothers Lsx car for 4 years with leaded and unleaded fuels.
Old Oct 11, 2009 | 11:08 AM
SoxXpupPeT's Avatar
Thanks alot for the replys guys.. i guess i wont be running any C16 in my camaro. what about my carbed 267 in my impala ???
Old Oct 11, 2009 | 07:28 PM
fuel's Avatar
i use the denso's to.with112 to 114 i never use any 93 any more, its a track car now.no problems yet.
Old Oct 11, 2009 | 07:58 PM
Nostang's Avatar
C16 should only be used with 15+lbs of boost or a 200+ shot of nitrous. Don't use any race gas unless you need it (detonation problems).
