Goin to the track tomorrow.......
Old Oct 19, 2009 | 11:58 AM
  #101
fergymoto's Avatar
Originally Posted by Speed Density
Your car looks like a pile of heavy ****, congrats.
That's a pretty mature statement coming from a high and might LS1Tech moderator. Isn't your job to post something more along the lines of what Jason did?
Old Oct 19, 2009 | 03:08 PM
  #102
Z-RATED94's Avatar
It might not have been proper, but I liked it.
Old Oct 19, 2009 | 06:37 PM
  #103
duh's Avatar
duh
Originally Posted by AChotrod
Guys Im not mad at 96caprice, we were all at the same track the same weekend.
Like I said congrats and the car moves out. Were you at the first RSD? I could swear that car was sitting next to me in the staging lanes????
Chris Ill look into that drag bar and see if its legal, Im not that worried about street manners. If I was the car would have a front sway bar. Its road noise I cant stand
To the rest of you guys, you had me rolling reading your coments towards 96. Thanks!!!
Mike, that bar mounts same as stock, except for the end links.....they're definitely stronger and do the job better. Best part is it should bolt right up to the 60 you got....it did with the 9" we had in the car. Biggest thing would be making sure it qualifies for the shootout, Which I don't think it wouldn't though.
Old Oct 19, 2009 | 06:43 PM
  #104
AChotrod's Avatar
Last years rules say sway bars yes, and drag bars no. Ill check it out.
Old Oct 19, 2009 | 07:33 PM
  #105
duh's Avatar
duh
That would be a loop hole then because I see drag bars as these
Old Oct 19, 2009 | 07:37 PM
  #106
AChotrod's Avatar
I agree, but I put up a post on www.ltxshootout.com B4 I spend the money
Old Oct 19, 2009 | 07:47 PM
  #107
duh's Avatar
duh
I'd say that's a wise choice
Old Oct 19, 2009 | 07:58 PM
  #108
86formula's Avatar
hmm maybe i wont be running against you guys since i have a Wolfe anti roll bar welded to my 12 bolt lol
Old Oct 19, 2009 | 09:30 PM
  #109
AChotrod's Avatar
Its legal as long as it uses poly mounts on the axle
86formula....I thought were on a level playing field????? lol
Old Oct 20, 2009 | 06:58 AM
  #110
86formula's Avatar
lol i havent even run with it and that hardly gives me the upper hand lol
Old Oct 20, 2009 | 07:20 AM
  #111
Colin91Z's Avatar
Better check again, Ray just posted over on the shootout forum sayin that it is NOT legal because it uses solid end links rather than poly....
Old Oct 20, 2009 | 10:52 AM
  #112
AChotrod's Avatar
Damn! Ill go check it out again. ! Its ok I dont have any money for it now anyways.
Old Oct 20, 2009 | 10:56 AM
  #113
AChotrod's Avatar
New post from Kyle still might be legal. Rule says sway bar yes anti roll bar No. I wait for a final decision.
Old Oct 20, 2009 | 12:59 PM
  #114
duh's Avatar
duh
Personally the solid endlinks shouldn't matter. with an Anti-Roll bar you can preload each side individually by where you put the arms at. Therefore you can add torsional rigidity, helpiing the launch of the car and keeping the front tires level. While the Spohn Drag Bar does similar it is not rigid between the axle and the bar, like the Anti-roll bars are. With the spohn bar, there is a little flexing that can take place because of the poly in-between the bar and the axle. I think that's where the biggest differences are and that should qualify it to work, since the stock bar works the same way......but that's me and I have no real say....
Mike if they say you can't use it that way, put it on with Poly end links and it'll do the same thing......
