.500" OD brass sleeve
Old Oct 11, 2009 | 09:42 PM
chevyjeff59401's Avatar
Default .500" OD brass sleeve
Well after asking how to fix the hole in my lt-1 head I was told to get some of this to have headbolt hole sleeved. Unfortunately I live in a relatively small town in Montana and it seems there is nowhere to buy it here, I tried to google it and haven't had any luck. If someone can lead me to a place to buy this online I would appreciate it. I found a machine shop willing to do the work for 15 bux but they don't know where to get the brass tube either. Thank you, Jeff
Old Oct 11, 2009 | 09:48 PM
94Z28-MSTGKLR's Avatar
That's the first I've heard of sleeving a bolt hole in a cylinder head. What exactly happened to it? Well unfortunatly I can't help you unless you want a set of used heads. I have some laying out in my storage out back. Good luck.
Old Oct 11, 2009 | 10:05 PM
https://ls1tech.com/forums/lt1-lt4-m...verported.html guess its a common problem
Old Oct 11, 2009 | 10:08 PM
Old SStroker's Avatar
Try McMaster-Carr on line.
www.mcmaster.com
"FIND" item 8859K33. It should be a 1/2 OD .472 ID brass tube. Four 12 inch pieces for $10.90 plus freight. You can order online and pay with a credit card. Delivery is usually 1-2 day via ground UPS.
They are plenty of other sizes.
Amazing company.
Razor_Blade's Avatar
Any machine shop should be able to machine a piece of brass into a sleeve. My wifes grandfather was a retired machinist. He used to make all sorts of gadets on the lathe in his garage.
Old Oct 11, 2009 | 10:33 PM
Thanks guys
