LE1 Dyno Results
Old Oct 12, 2009 | 04:54 PM
BizZzatch350's Avatar
Moderator
Great numbers Moe, whens your car going to be done?
Old Oct 12, 2009 | 06:03 PM
Bersaglieri's Avatar
Those are the numbers I'd expect for a LE1/CC306 car, proven 400rwhp combo. Hopefully we can get a graph on here.
Makes me want to keep my CC306 and send another set of heads to Lloyd.
Moe what's your location?
-Dustin-
Old Oct 12, 2009 | 09:56 PM
Speed Density's Avatar
hashtagBMW
Good Job Moe!
Old Oct 12, 2009 | 10:49 PM
CamaroRacing12's Avatar
i wonder what that combo woulddo on a 350ci motor
Old Oct 12, 2009 | 11:06 PM
AChotrod's Avatar
Probably more. 355 really is not much bigger and its heavier
Old Oct 12, 2009 | 11:10 PM
Cruzer23's Avatar
i wonder what the #s would be through an auto and 9"
would there be much of a difference in #s if it was a 383 instead of a 355?
Old Oct 12, 2009 | 11:11 PM
Colin91Z's Avatar
^^^Agreed. The only time you'll see much difference in power from a 350 to a 355 ci (all other variables the same of course) is if the 355 has a rotating assy that weighs the same or less. Even then, likely less 5hp or less between the two. This is especially true with small valve heads such as the LE1s.
Old Oct 13, 2009 | 12:04 AM
MasterTomos's Avatar
what benefits are there of a 355 build then? Just the fact that it's sturdier?
Old Oct 13, 2009 | 01:29 AM
It's been done plenty of times on a 350 with similar results. Check out CamaroZ28.com. It's funny, new things on here are years old on there
-Dustin-
Old Oct 13, 2009 | 06:26 AM
djm_e22's Avatar
Yep it was me!!!! Before the dynotune I had it mail tuned and only made 377rwhp and 349lbs of torque. Here is one of the graphs this was the 402rwhp sae 386lbs of torque sae one though. I never took the picture of the 403 sae rwhp. Sorry about the picture I should have taken it closer. Remember this is a 355 with a 306cc cam through a 9" with some huge 315's out back.
Old Oct 13, 2009 | 07:23 AM
z_speedfreak's Avatar
wow awesome numbers!!!!!!
Old Oct 13, 2009 | 08:09 AM
  #32
moehorsepower's Avatar
The motor is 90% complete, Clark is going to start changing out the wiring harness and put the motor on the new tubular K-member and start putting her together.
Old Oct 13, 2009 | 08:11 AM
  #33
-Dustin-
I'm in San Antonio, but I use Dynos at Maxwell Dodge in Round Rock, One in Waco, actually Valley Mills, a couple in Ft hood and Killeen..
Old Oct 13, 2009 | 08:36 AM
  #34
Colin91Z's Avatar
Yes.
Most of the time, a 355 is built because the factory bottom end is worn. The .030 over-bore is more of a neccesity when rebuilding rather than a performace-enhancing mod. While you're in there, might as well add forged pistons+rods and good bearings to make it sturdier.
Old Oct 13, 2009 | 08:39 AM
  #35
Colin91Z's Avatar
-Dustin-
^^^ Very True.
Old Oct 13, 2009 | 09:22 AM
  #36
myltwon's Avatar
depends on compression ratios between the two as well
depends on the transmission, if you're talking 4L60e with a convertor that isn't ridiculously loose, I'd imagine prolly somewhere in the 380s
Old Oct 13, 2009 | 10:57 AM
  #37
AChotrod's Avatar
True! But lets just say with a stock CR, it would be very close or make a tad more on the stock short block assuming the 355 isnt all light weight parts also
Old Oct 13, 2009 | 11:24 AM
  #38
myltwon's Avatar
yeah def, rotational mass kills hp
Old Oct 13, 2009 | 12:01 PM
  #39
AChotrod's Avatar
Tell me about it, my Steet Twin clutch robbed 8.5 hp since its 20lb heavier than a single disc clutch. No worries though since it did go faster.
Old Oct 13, 2009 | 12:41 PM
  #40
djjab57's Avatar
Man i cant wait to see what my 355 LE2 set up does. Seeing this makes me very happy
