water pump question
Old Oct 16, 2009 | 09:14 PM
96Formula6spd's Avatar
Default water pump question
Hey guys my water pump is leaking at the gasket so tomorrow I was going to replace those. I have taken the engine apart a few times but my question is what do you have to remove to get the water pump off?
Old Oct 17, 2009 | 12:10 AM
the_merv's Avatar
Veteran: Air Force
Remove Intake Ducting, Drain Radiator, take all of the Coolant Hoses off, unplug connectors on Water Pump and remove the 6 Bolts. The one by the Power Steering can be tricky.
Old Oct 17, 2009 | 09:10 AM
SS RRR's Avatar
Village Troll
Using a wobbly extension for the bolt behind the w/p pulley makes the job extremely easy.
Old Oct 17, 2009 | 09:18 AM
the_merv's Avatar
Veteran: Air Force
The LT1 has a Water Pump Pulley..
Old Oct 17, 2009 | 10:28 AM
RamAir95TA's Avatar
He meant power steering pulley.
If you haven't taken done the AIR pump delete, it needs to come off as well. One of the bolts on the driver side doubles as a stud for the AIR pump.
Old Oct 17, 2009 | 05:01 PM
Yeah had to take the ps off and the coil to get it out
Old Oct 17, 2009 | 08:02 PM
LoudGM's Avatar
Well while it's out go ahead and put an electric on back on. (:
Old Oct 17, 2009 | 10:29 PM
I would buts its a brand new regular pump. Needed something cheap since I had to rebuild my engine on a very low budget.
